Hydraulic stop working on new holland tn75d
   / Hydraulic stop working on new holland tn75d #1
Bingoose
Tabusintac new-brunswick
New holland
Juste got a used new holland tn75D 2004. Used it for few hours and working fine. I stop it and wen I started back the loader and 3 point hitch dont work. aboseloutely notting. It was working fine wen stop. Check the oil and is fine. I'm new to tractor. Please help.
   / Hydraulic stop working on new holland tn75d #2
Check, clean or replace filters.
Check hyd level.
Is hyd pump turning?
Do you have a hyd gage?
The pump Is turning, the fluid Level ok, no gauge. CAN it stop working from a stop to a strat?
   / Hydraulic stop working on new holland tn75d #4
If the pump lost prime it would not pump fluid.
If the pump is good and you activate a valve lever, something should happen, because the fluid is flowing through all the valves.
A hyd gage would tell you if pressure is being developed.
Loosen or remove a pressure hose and place in a bucket to check flow.
   / Hydraulic stop working on new holland tn75d #5
Make sure the lever is not spinning on it's shaft going into the trans.
I can presse on one of the coupler not used and there is no oil or just à drop coming out.
   / Hydraulic stop working on new holland tn75d #7
That well not tell you much unless you can hold the coupler open then move the lever for that rear remote. One way you well get none and the other way you should get oil coming out.
   / Hydraulic stop working on new holland tn75d #8
If no fluid is coming from an open ended hose, then you are not pumping.
You said the pump is turning, but how do you know this. If the shaft as Leejohn mentioned is sheared off, the pump will not be turning.
Have you messed with any hoses/QD's and perhaps deadheaded the pump?
Hydraulics:
Valves: 2 to 3
Pump flow: 12.4 gpm [46.9 lpm]
Tanks, no, i juste stope the tractor and she was not working after.
   / Hydraulic stop working on new holland tn75d #10
Run a hose directly from the pump OUT port into a 5 gal bucket and check for flow.
If no flow, then either the shaft is sheared off or you have lost prime.
Check for in tank filter. If it is clogged, you will have no flow.
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Cat TH407C Telehandler (A52748)
Cat TH407C...
