Hydraulic stop working on new holland tn75d
   / Hydraulic stop working on new holland tn75d #1
Bingoose
Tabusintac new-brunswick
New holland
Juste got a used new holland tn75D 2004. Used it for few hours and working fine. I stop it and wen I started back the loader and 3 point hitch dont work. aboseloutely notting. It was working fine wen stop. Check the oil and is fine. I'm new to tractor. Please help.
   / Hydraulic stop working on new holland tn75d #2
Check, clean or replace filters.
Check hyd level.
Is hyd pump turning?
Do you have a hyd gage?
The pump Is turning, the fluid Level ok, no gauge. CAN it stop working from a stop to a strat?
   / Hydraulic stop working on new holland tn75d #4
If the pump lost prime it would not pump fluid.
If the pump is good and you activate a valve lever, something should happen, because the fluid is flowing through all the valves.
A hyd gage would tell you if pressure is being developed.
Loosen or remove a pressure hose and place in a bucket to check flow.
   / Hydraulic stop working on new holland tn75d #5
Make sure the lever is not spinning on it's shaft going into the trans.
I can presse on one of the coupler not used and there is no oil or just à drop coming out.
   / Hydraulic stop working on new holland tn75d #7
That well not tell you much unless you can hold the coupler open then move the lever for that rear remote. One way you well get none and the other way you should get oil coming out.
   / Hydraulic stop working on new holland tn75d #8
If no fluid is coming from an open ended hose, then you are not pumping.
You said the pump is turning, but how do you know this. If the shaft as Leejohn mentioned is sheared off, the pump will not be turning.
Have you messed with any hoses/QD's and perhaps deadheaded the pump?
Hydraulics:
Valves: 2 to 3
Pump flow: 12.4 gpm [46.9 lpm]
Tanks, no, i juste stope the tractor and she was not working after.
   / Hydraulic stop working on new holland tn75d #10
Run a hose directly from the pump OUT port into a 5 gal bucket and check for flow.
If no flow, then either the shaft is sheared off or you have lost prime.
Check for in tank filter. If it is clogged, you will have no flow.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2002 John Deere 5220 (A50120)
2002 John Deere...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
