Hydraulic Steering Failing
   / Hydraulic Steering Failing #1
Believer
I've got a Yanmar compact loader backhoe, a CBL 40. Has 430 hours on it. The steering is failing....turn the wheel but its moving very little, worse one direction than the other. Came about gradually. I've put some heavy loads on this tractor. I'm guessing I need to rebuild the steering cylinder but wanted to seek advice or troubleshooting tips beforehand. Are ther other possible causes? Everything else on tractor works fine.
   / Hydraulic Steering Failing #2
If you raise the front wheels off the ground do they steer correctly?
First thought is the seals in the steering cylinder leaking. Depending on how bad they are will they turn if you physically push on the front tires with them raised ? If they turn then I would definitely suspect bad seals on the cylinder
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
