hydraulic steering column
/ hydraulic steering column #1
nsmithnd
Bismarck, ND
Ford 1700
Would a person be crazy to not snag this unit?
(power beyond - 6.1 cubic in per revolution - 2000 psi - 5 gpm - $100)
Would really like to add power-steering to the Ford 1700 with loader (pressure relief set at 2000 psi and rated at 5.3 gpm per the Ford specs).
I suppose the steering valve has to be first in-line with power beyond feeding the loader valve (which also has power beyond).
Or can the loader valve be first to drop the flow to the steering valve?
Or should I pass on this one?
-Neil
/ hydraulic steering column #2
I think I would get it, If that is a char-lynn pump on the end, that sells for $300 to $500. Make it work after the fact or resell it.
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
