Hydraulic seals replacement
/ Hydraulic seals replacement #1
miteyo
Marietta, Ga
Kubota B20
Hi. Can someone tell me how hard is it to replace the hydraulic
seasl on the front bucket of a kubota B 20. Are there any specials
tool required? Thanks, miteyo
/ Hydraulic seals replacement #2
Hi. Welcome.
Not a hard job. May need a spanner wrench to get the end cap off. Clean is paramount so not to contaminate the fluid or damage the seal. Careful handling the seal and shaft. May want to consider a complete overhaul of the cylinder at this time as well.
If not a bad leak may want to time it with the hyd. oil change schedule.
/ Hydraulic seals replacement #3
Might want to check around for rebuild cost.
I just got a cylinder rebuilt for my Kubota M4700
for $45.
I didn't have the tools with me in Mississippi.
Here's several links:
https://www.youtube.com/watch?v=LmznN2XaPMY
https://www.youtube.com/watch?v=XNMC-CKrMjU
How to Disassemble, Rebuild or Repair Hydraulic Cylinders and FAQS
Thank you! I was told that it was very hard, that taking the seals was easy but, putting them
back in was way to hard, and that a special tool probably was used to do the job.
(2) KMC Strip Till Row Markers (A64127)
(2) KMC Strip Till...
2022 EZ-GO ELITE...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
