Backhoe hydraulic seal on 110 tlb
   / hydraulic seal on 110 tlb #1
BruceG
Chesterfield
john deere
I took my backhoe stabilizer cylinder apart and installed the new seals and when trying to put the hydro rod guide on the rod it seams real tight when it tries to go
through the bearing. Is this normal and should I press it on. This is the first time I worked on a hydraulic cylinder so I don't want to damage the bearing. I did have a new rod made and the seals fit fine but the bearing appears real tight on the rod.
Thank you for any help.
   / hydraulic seal on 110 tlb #2
Take a pic so we can see what you're calling a bearing. It should be tight but I don't think you need a press. Now getting the Piston back into the cylinder housing can be quite tight and I've used shim in a can to gap the transition between the seal and cylinder and then use a dead blow to persuade it back in.
I've done quite a few cylinder rebuilds this way and actually will be doing both on my 110 real soon.
Matt
They call it a bearing in the instructions and ware ring on the diagram. You can see from the picture how far I can put it on until it gets really tight. I took the ware ring out and the rod guide goes in no problem.
   / hydraulic seal on 110 tlb #4
This video may help.
it starts as 10:21
Thank you for the video I'm putting the piston on the rod I already have the assembly out. Does anyone know the diameter of the rod? The machine shop used 40MM rod and I think it's the wrong size rod they made because I just tried to put the piston on the rod and it won't go on.
   / hydraulic seal on 110 tlb #6
The issue in advising on this one is complicated due to the non oem part. As I suggested in my previous reply a can o shim was the secret for me in getting the piston rings into the cylinder. Since you've got a non standard part you really gotta be careful. If you have the old part take a micrometer to it and then compare the diameter.
Matt
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2018 Ford F-350 4x4 Ext. Cab Stellar EC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
