Hydraulic saw
/ Hydraulic saw #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
This is a well built hydraulic saw that could be built or adapted to the Pt. It also swings left and right using a hydraulic cylinder. This would save wear and tear on the steering system.
/ Hydraulic saw #2
yeah, but you really need that full roll cage with wire mesh, cause odds are the first tree that you swipe with that sucker is going to come crashing down on top of you.
Wouldn't that be fun?
/ Hydraulic saw
I am assuming that who ever is using this saw, knows how to cut a tree. I am not suggesting that someone try and cut a 100 ft tree with a 60 in base. Use what ever skills you have to get the job done. Think positive.
/ Hydraulic saw #4
I could use something like that last week when I had to cut through some sapling with vines and prickers , must weigh alot .
/ Hydraulic saw #5
I was just thinking about one of those things the other day. It wouldn't be 2 hard to build one...maybe a little lighter, just for up to 6" or so diameter.
Hydraulic motor to run the blade, some sort of spring tension to pull the blade into the tree, hydraulic cyc. to pull the "mouth" open.
2" or 3" sq. tubing for frame work.
/ Hydraulic saw
Here is a picture of a hydraulic chain saw. Very small and light weight.
/ Hydraulic saw
Bill, Thanks for posting the manufacturer. As I scan the Internet, I just copy all the interesting tools that I see, hoping that someday, I can make something similar.
/ Hydraulic saw #9
Great pictures and links J.J. and Bill!
Ironically , I thought that would make an awesome pole pruner...then I checked the link. Too late! But it must have been a good idea then. /forums/images/graemlins/smile.gif
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63118)
2012 Isuzu NPR HD...
3PT BOOM POLE (A63745)
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63118)
2019 Cadillac...
2004 TMP 32' T/A PIPE TRAILER (A63569)
2004 TMP 32' T/A...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
