Hydraulic Return Hose Collapse
/ Hydraulic Return Hose Collapse #1
jmurtap
JD 460
The rubber hose that runs to the pump on our JD is collapsing when it is running. I have changed the filter, hose, cleaned the suck-up screen and put fresh hydraulic oil in, what else can I do.. All the functions do work, just considerably slower than they should.
Thank You !!
/ Hydraulic Return Hose Collapse #2
If that hose is coming from the tank to the pump, then it is a suction hose and needs replacing. If you starve the pump long enough, some damage can occur. A new suction hose should not cost that much. A wire insert might help. If that hose is a new hose, was it designed for suction, or just plain hose?
If that is a new stiff hose, then you have a blockage somewhere, filter, inside tank obstruction, etc.
You can try blowing air back through the suction tube, but might get messy.
You could do a test of the pump by removing the suction hose, and block off the tank opening, and using a new hose, suck fluid from the container, and dump the pump output flow back into the container.
/ Hydraulic Return Hose Collapse #3
jmurtap,
The suction hose should not collapse in any circumstances......You need to replace it with the proper suction hose....
Suction hose will have a "slinky" wire molded into the core of the hose....make sure it is not a regular hyd hose used for pressure cuz the liner is wrapped with wire braid on the outside of the inner liner......allowing it to collapse during vacuum....
/ Hydraulic Return Hose Collapse #4
I agree with the other posts. One more thing to to check is the vent. If the vent is pluged it can cause the hose to collapse.
Bill
I will check the tank Thank You!!
This hose doesn't have a wire inside of it, but it is a molded 3 port hose
Where would the vent be at?
Thank You !!
/ Hydraulic Return Hose Collapse #8
The fill cap may have a small hole somewhere. Top, side or thread area.
There has to be a vent, as the fluid expands and contracts caused by temp differential.
/ Hydraulic Return Hose Collapse #9
wdchyd said:
jmurtap,
So true. Change your suction hose with the proper hose. I personally saw a John Deere excavator blow a $7,000 pump because they were sold 1 wire hose for suction hose. Give Ken a ring over at DHH or visit a reputable hose shop.
I purchased hose directly from John Deer, it's very odd hose, no way its the wrong hose.
/ Hydraulic Return Hose Collapse #12
Is it possible there should be an internal spring-wire inside the hose..??
I couldn't see the JD link.....
/ Hydraulic Return Hose Collapse #14
When you changed out the hose, did a lot of fluid come out?
No not very much, 1/4 of a quart maybe
/ Hydraulic Return Hose Collapse #16
I see where you're going with this JJ....maybe a restriction in the tubing and/or fittings to the reservoir..??.....It's gotta be somewhere between the hose/ reservoir/suction screen..........
make sure the suction tubing hasn't been hit/squashed...
It looks in good shape I'll pull it off and check for a blockage.
Thanks Guys !!!!
/ Hydraulic Return Hose Collapse #18
Is the title for this thread [ the return hose ]correct , or should it have been suction hose.
/ Hydraulic Return Hose Collapse #19
I would say JJ you hit it right on post #2.....calling it a suction hose...:thumbsup:
suction hose, srry this is the first tractor I've ever dealt with.
