Hydraulic Return Hose Collapse
   / Hydraulic Return Hose Collapse #1
jmurtap
JD 460
The rubber hose that runs to the pump on our JD is collapsing when it is running. I have changed the filter, hose, cleaned the suck-up screen and put fresh hydraulic oil in, what else can I do.. All the functions do work, just considerably slower than they should.
Thank You !!
   / Hydraulic Return Hose Collapse #2
If that hose is coming from the tank to the pump, then it is a suction hose and needs replacing. If you starve the pump long enough, some damage can occur. A new suction hose should not cost that much. A wire insert might help. If that hose is a new hose, was it designed for suction, or just plain hose?
If that is a new stiff hose, then you have a blockage somewhere, filter, inside tank obstruction, etc.
You can try blowing air back through the suction tube, but might get messy.
You could do a test of the pump by removing the suction hose, and block off the tank opening, and using a new hose, suck fluid from the container, and dump the pump output flow back into the container.
   / Hydraulic Return Hose Collapse #3
jmurtap,
The suction hose should not collapse in any circumstances......You need to replace it with the proper suction hose....
Suction hose will have a "slinky" wire molded into the core of the hose....make sure it is not a regular hyd hose used for pressure cuz the liner is wrapped with wire braid on the outside of the inner liner......allowing it to collapse during vacuum....
   / Hydraulic Return Hose Collapse #4
I agree with the other posts. One more thing to to check is the vent. If the vent is pluged it can cause the hose to collapse.
Bill
I will check the tank Thank You!!
This hose doesn't have a wire inside of it, but it is a molded 3 port hose
Where would the vent be at?
Thank You !!
   / Hydraulic Return Hose Collapse #8
The fill cap may have a small hole somewhere. Top, side or thread area.
There has to be a vent, as the fluid expands and contracts caused by temp differential.
   / Hydraulic Return Hose Collapse #9
wdchyd said:
jmurtap,
So true. Change your suction hose with the proper hose. I personally saw a John Deere excavator blow a $7,000 pump because they were sold 1 wire hose for suction hose. Give Ken a ring over at DHH or visit a reputable hose shop.
I purchased hose directly from John Deer, it's very odd hose, no way its the wrong hose.
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
