Hydraulic reservoir building pressure?
   / Hydraulic reservoir building pressure? #11
It's a linkage that hooks to the rockshaft upper arms, most of the time on the right arm. It stops the 3pt from bottoming out all the way up. I do not have a picture for you, sorry.
Well I took the hydraulic pump off. Now trying to get a rebuild kit for it or see how much a new unit is. The problem I have is there is a 6 spline sleeve that goes over the spline shaft that is worn bad. So either I have to get the spline shaft machined for a key way or buy new pump gears which along with a rebuild kit are about impossible to find. Anyone know of a good place to look for a rebuild kit for a KYB pump? Number is GPH1-35CY if anyone has one laying around
(40) 2" X 2" X 79" TUBING (A54756)
(40) 2" X 2" X 79"...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2006 John Deere HPX Gator 4x4 Utility Cart (A55787)
2006 John Deere...
