hydraulic res size?
   / hydraulic res size? #1
saiga
meridian, idaho
2005 MF 1533
im using a 12 gpm prince pto pump to run a home made (kind of) backhoe . i have an 11 gallon reservoir. is that cutting it too close? does anyone know where to get inexpensive tanks. any thoughts welcome
   / hydraulic res size? #2
im using a 12 gpm prince pto pump to run a home made (kind of) backhoe . i have an 11 gallon reservoir. is that cutting it too close? does anyone know where to get inexpensive tanks. any thoughts .welcome
I believe your tank size is supposed to be 2 times the pumps GPM. So if your pump is 12 GPM, you need a 24 gal tank. However, if you have a small radiator with fan, you can run the return fluid through the radiator be fore dumping into tank.
I believe Surplus Hydraulics has tanks, and Baileynet.com
https://www.surpluscenter.com/home.asp
http://baileynet.com/index.php
   / hydraulic res size? #3
11 GPM reservoir for a 12 GM pump is a great match. The "ideal" setup is to match the 1:1, but you are so close it does not matter. Most consumer grade logsplitter's for instance have very small resivoirs.
   / hydraulic res size? #4
   / hydraulic res size? #5
It wasn't that long ago that the common design rule was to size the reservoir at 2:1. Recently, the rule of thumb has moved to 1:1. Most of the hydraulic fluids today contain additives that allow the 1:1 design. Just make sure your return lines are sized to slow the return flow to around 3fps.
   / hydraulic res size? #6
"24 gal tank."
All I can think of is $150 worth of oil!
   / hydraulic res size? #7
Don't you think a 1:1 is kind of illogical. The most important part of a hydraulic system is the fluid, and the temperature of the oil, very important. The turn around time for the oil in a 1:1 doesn't give time for the heat to dissipate, expunge the air, or let contaminants settle. While it is true that hydraulics in mobile hydraulic systems have shrunk, The object was to save space, and doing so, they expect the system to be a little bit more heat tolerate. I also have not seen the 1:1 ratio mentioned very much, while I have seen the others, such as 2:1 and 3:1 . I can understand that certain systems could get away with small tanks, when the system is using intermittent hydraulics. Working a pump at 100 % . I think the the 2:1 or better will give more longevity to the system.
That is my take on it, the less heat you have, gives a better operating system for the hydraulic fluid.
What ever one wants to do , he can, he is the project manager.
   / hydraulic res size? #8
Here it states 3 to 5 time the flow rate. (Cha-Ching)
http://www.hydraulicsupermarket.com/upload/db_documents_doc_10.pdf
But I'm guessing they are talking some pretty big equipment and in constant use. I've asked this question before and have decided for me 1:1 or maybe even a little less will be adequate. I figure I could always place a temp gauge on the system to keep an eye on it. How big are the reservoirs and pumps that come with the self contained backhoes like Woods? I'm also guessing that the larger the diameter of the cylinders being used the more heat generated during use. Ok the more volume of heat produced and therefore larger tank required.
Wedge
   / hydraulic res size? #9
As JJ mentioned the heat is a major concern, so if you wan't to conserve space and size of the tank you may need an oil cooler. I would definitely have a temperature guage to monitor the system. You can get by with a 1:1 system as long as the oil remains cool enough but I would prefer a 2:1 setup.
Steve
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2025 Icon Electric Cart (A51694)
2025 Icon Electric...
