Backhoe Hydraulic Ram Sizes
   / Hydraulic Ram Sizes #11
Galen and JJ
Ok, in order to figure out how hydraulics can work... I started drawing it all out to get it clear in my mind how to proceed with plumbing in the rear remotes.
Can either of you tell me what the 4-metal lines I've identified on the draft sketch as "unknown lines" are...and what they do ?? (I've circled the lines in question with little clouds).
When I'm done with all this reasearch...I'll clean up my drawing and and post a before adding remotes sketch and an after remotes added sketch. In case it will assist the next guy as dumb as I am about all this :D
Thanks in advance
Bradly,
I printed your sketch, and will hand sketch in the auxilary valve you intend to install to the rear. My problem is I don't know how to send it back to you on the computer. Also I am working my Mahindra booth at the local Home show so I am quite busy till the weekend is over. Let me know how I may get the sketch to you.
Thanks JJ
I bought that nice Service Manual... problem is a lot of the pages tell you what to take apart in what order, but very few pages tell you what the item is. I'm looking thru pages and pages and can't figure out if the Hydraulic pump is attached to the motor or back at the trans area somewhere(or in the trans itself even).
Well, I'll keep chipping away at it til it's figured out.
Thanks again for the help.
I'd just order that rear remotes kit, but before I pay $600 I'd like to know what I have on the tractor now and what is really gonna be needed. Hope that don't make me a cheap son of a gun. :)
Thanks again
Brad
Galen
I'm sorry to put you to trouble... take your time.
If you make a sketch, if you want to... you can fax it to 909-923-0858 OR if you want to drop it in the mail, my address is:
7171 Redwood Ave.,Hesperia,CA
I will send you back reimbusement $ for the letter, or the fax for sure.
Thanks for going to all the trouble trying to help me...I appreciate it very much.
I'm kind of happy cause while under the tractor trying to figure out these hyd lines, I noticed trans fluid all over the bottom of a housing, and in wiping away the dirt ,I found 2 of the housing bolts (that go thu a type of rectangle piece of steel) were real loose. I tightened them up and if it didn't stop the trans leak it slowed it WAY down. I can't wait to go out this morning and see if it actually stopped the leak.
The guy I bought tractor from couldn't figure out where it was leaking either, and it's been dripping since I owned the machine, but been getting worse. So this research has already been a win-win!
Brad
   / Hydraulic Ram Sizes #14
I will fax it to you on Monday, also if you haven't solved the leak, I may be of some help there also.
   / Hydraulic Ram Sizes #15
Bradly,
I faxed you the quick sketch on plumbing the auxillary valve. When you get an auxillary valve, make sure it has a PB port, and you will have to purchase a Power Beyond sleeve or adapter to go with it.
Thanks much Galen.
I'll get it out and study it at lunch time...I'm a visual person so diagram is only way I get some things.
Thanks again, and when I start this I'd like to check with you first to see if your shop has any of what I need for sale.
Even though I know the help was without strings...I sure appreciate it.
Brad
1R PLANTER (A52708)
1R PLANTER (A52708)
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2014 Toro Groundsmaster 4500D 5- Deck 4WD Rotary Commercial Mower (A56857)
2014 Toro...
2011 International DuraStar 4300 12ft Flatbed Truck (A55973)
2011 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
