hydraulic ram problem
/ hydraulic ram problem #1
markythesparky
estesia
I have just bought a second hand etesia mvehh and i knew the hydraulic grass emptying did not work but it was the right money, i have had a good look at it and established that there is oil going to the pump from tank , and also at the control valve port P with the pipe diconnected and engine running ,you also get oil at ports A and B with the pipe disconnected and the valve is operated with engine running,but if you diconnect the pipes from the rams (see pic)you only get s dribble of oil coming out.Am i right in suspecting the relief valve in the control valve body or the control valve its self .Not sure of the spec of the pump (see pic)so could not check the exact flow rate
/ hydraulic ram problem #2
Heck, I had to look up what that was! Sorry, can't help you, hopefully somebody will be along to answer your questions.
/ hydraulic ram problem #3
BUT just getting oil at ports does not indicate working pressure.... You need pressure gauge in system to confirm working pressure, not just presence of oil...
/ hydraulic ram problem #4
Are you saying you get oil out of ports A and B at the valve.....but then hook hoses up to those ports and get NO oil out of the hoses. Sounds like the hoses are not allowing oil to pass through them.
/ hydraulic ram problem #5
Piston on cylinder rod needs new internals. It's just bypassing inside the cylinder. Just hook one hose up. See if fluid comes out where other hose goes on. If fluid comes out and cylinder no move, it's the piston.
Quick update
I think i may have found the problem the pump drive sits in a slotted drive on the puller and it is very worn and it appears that when the pump is under load it slips but with no load it pumps , i have ordered a new puller so will see if that works
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2012 GMC Sierra SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
