Hydraulic quick connect repair
/ Hydraulic quick connect repair #1
scottmarsc
norwood, ny
kubota l3240
My Kubota L3240 has Faster HNV12NPT quick connects for the 3-Pt and backhoe connection that are leaking. My local Kubota dealer only lists a replacement connector at the cost of $30 when I believe the o-ring and PTFE seal are all that is necessary to fix the leak. Anyone have a reference or source for replacing these seals? All the automotive and tractor parts stores in my area have left me looking at a $30 fix as the only option.
/ Hydraulic quick connect repair #2
Carefully remove the
O-ring and take along with you to your parts store that sells O-rings. The PTFE is typically a backup ring that does not require replacement
The O-ring goes on pressure side of backup.
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
Jack Daniels Metal Sign (A65583)
Jack Daniels Metal...
(3) Corral Gates (A66408)
(3) Corral Gates...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
