Hydraulic quick connect repair
   / Hydraulic quick connect repair #1
scottmarsc
norwood, ny
kubota l3240
My Kubota L3240 has Faster HNV12NPT quick connects for the 3-Pt and backhoe connection that are leaking. My local Kubota dealer only lists a replacement connector at the cost of $30 when I believe the o-ring and PTFE seal are all that is necessary to fix the leak. Anyone have a reference or source for replacing these seals? All the automotive and tractor parts stores in my area have left me looking at a $30 fix as the only option.
   / Hydraulic quick connect repair #2
Carefully remove the
O-ring and take along with you to your parts store that sells O-rings. The PTFE is typically a backup ring that does not require replacement
The O-ring goes on pressure side of backup.
Ingersoll Rand TS5 80 Gallon Air Compressor (A51573)
Ingersoll Rand TS5...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
