Hydraulic QD's
/ Hydraulic QD's #1
mr.wayne
Sulphur, Louisiana
I had two remotes put on at the dealer. With my hoses plugged to both remotes, the bottom return does'nt want to stay connected. It will bew ok for a while, but will pop out numerous times while working. I've been using the lower remote for the hyd. top link. Yesterday I plugged into the top outlets and it stayed plugged up. Could the quick coupling be bad? These are brand new and have 10 hrs. on my tractor. Any one else evwer have this problem?
Thanks Wayne
/ Hydraulic QD's #2
Have the dealer change the female QD. There is probably something not seating properly. This assumes you are fully pushing in the male end until it snaps and the outer slide ring goes back to it's normal position. Connecting with the engine stopped and the remote's pressure on the work port relieved will help too.
