Hydraulic Pump
/ Hydraulic Pump #1
JennyBaker
Union City, TN
Kubota M4900
I am looking for either a rebuilt or a kit to rebuild the hydraulic pump for a 1998 Kubota M4900 special utility tractor. The dealer will only sell me a new one that costs $1,100. Anyone else have this same issue?
/ Hydraulic Pump #2
There are not rebuilds to my knowledge. These pumps are aluminum bodies so when 1 goes bad, it goes bad. I do not ever remember seeing 1 that was leaking without internal damage (that is not to say it can not happen, I just have not seen it). What is wrong with yours?
/ Hydraulic Pump
It is leaking fluid. Do you know if there is a gray market or another pump that will work with this tractor?
/ Hydraulic Pump #5
Is there any manufacturers information on the pump? I.e. Make, model, etc.. If yes you may be able to get a replacement but suspect that the pump for Kubota is proprietary.
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
Lincoln Welder (A62613)
Lincoln Welder...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
