Hydraulic pump
/ Hydraulic pump #1
DUMBDOG
Central ND, Central FL
NH 1630 W-7308 FEL/ Kubota L4630GSTC W-LA853 FEL WQ/A-CC 2544
This last June while hooking up the plow to the three point my L4630GSTC was idling and it just picked up about a 100 rpm's. After that the shifter no longer shifted, three point did not work, loaded did not work and the PTO acted like it worked but did not turn. It is still sitting there as I was to busy to fix it and then it got to cold. The plow is still attached to the three point with no way to take it off.
Changed the hydraulic filter and narrowed it down to the pump.
Has anyone else had this problem? Have searched the posts but no hits on the search.
/ Hydraulic pump #2
Do you have any steering? If all functions are dead then it is probable your hydraulic pump drive sheared.
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
JOHN DEERE PUMPING UNIT (A64278)
JOHN DEERE PUMPING...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
