hydraulic pump testing L48
/ hydraulic pump testing L48 #1
brain55
Veteran Member
Brentwood, CA
Customer complained that the loader didn't seem to have the power it once did and was slow lifting a loaded bucket. Not being from the school of "put a pressure gauge on it" I usually skip all that and eliminate the pump first.
Here's my flowmeter installed. At 2000 rpm the no load flow was about 10 gpm. At 1000 psi the flow had already dropped to 7 gpm and at 2000 psi the flow was less than 5 gpm. Had I put a pressure gauge in the system I'm sure it would have read real close to spec. Whatever that may be. With the flowmeter I don't need to know. If I would have still had 8.5 gpm or more at 2500 psi I would have started looking at other possible problems. Pumps can make pressure all day long but with no flow they won't do any work.
Brian
/ hydraulic pump testing L48 #2
That's the right way Brian.....been doing it that way for over thirty years
I generally use 50 percent efficiency at max operating pressure (in your case 5 gpm) a point of absolute replacement.....new pump at 85-90 percent would be ok.....anything in between is a judgement call from the customer
I like to use the flow meter for monitoring after a new pump install too, the load valve makes a good break-in tool
70% is usually my threshold for replacement, especially if they are complaining about performance.
Brian
The one part I didn't like about the job was telling the customer that he needed a $1000 hydraulic pump plus the oil, filter, and labor. Fortunately he didn't hesitate, wince, or blink, he just said "do it". I like that kind of customer. He puts about a hundred hours a year on this machine and never hesitates to make proper repairs including cosmetic repairs. When you're a plumbing contractor you can't afford to show up with a shoddy machine in his opinion.
Brian
/ hydraulic pump testing L48 #5
Brian,
How many hours are on this machine? If the pump is that shot I would be looking for the reason why.
It only has about 1300 hrs. When I pull the pump next week I will definitely tear it apart and have a look inside. It went about 8 years where I wasn't the guy doing the maintenance so it may have missed some fluid changes. It didn't show any signs of cavitation when I had the flowmeter on it, but that doesn't mean that it didn't at another point.
Brian
/ hydraulic pump testing L48 #7
Brian
I'm following this with a lot of interest and wondering if anything crosses over to the M59. Did the customer say that there were any symptoms leading up to where he brought it in? Did he say it made any odd noises? or anything?
So far our M59 seems to be fine, but the pump will whine until it warms up - then it's silent. It does make me careful to let it warm the pump and fluid for a bit before putting it in gear for use. I also use a block heater in the winter and that works nicely. Maybe being over-cautious. It didn't do the cold whine thing when new; the cold pump whine started at about 300 hrs; now over 500 and no change that I can tell so ...... might be normal wear.
Say, that's a nice flowmeter. Looks handy. Who makes it?
rScotty M59, JD530, some others
I believe it was gradual until it was problematic. It didn't sound like it worked one day and not the next. Though it wasn't mentioned when I was there in January working on some of his other equipment.
Not sure of the brand on the flowmeter. I bought it from the first dealer I worked for when he went out of business back about 1993.
Brian
/ hydraulic pump testing L48 #9
Brian
Brian, I was looking through some old posts and wondered if you remembered anything about this repair... How did it turn out when you opened up the pump?
rScotty
rScotty
The pump was worn out from being worked. It didn't look like it was a lack of oil or cavitation.
Brian
/ hydraulic pump testing L48 #11
My L48 hydraulics have weakened to the fix it point. I'd like to do a flow test as per above but other than rebuilding cylinders I've no hands on experience. I'd be most appreciative if anyone would walk me through the procedure. Joe
2020 DITCH WITCH HX30 VACUUM TRAILER (A59823)
2020 DITCH WITCH...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
1993 East 39' Dump Trailer (A60462)
1993 East 39' Dump...
MASSAGE CHAIR (A58214)
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
