Hydraulic pump specs Jinma 354
   / Hydraulic pump specs Jinma 354 #1
longharbor
New Zealand
New Holland Boomer 35
I have a Jinma 354 and want to attach a hydraulic log splitter that needs a hydraulic pump delivering minimum 11 gallons per minute to operate. There are no specs for hydraulic pump output in the manual and I wonder if anybody could provide this information.
   / Hydraulic pump specs Jinma 354 #2
I run a hydraulic 3 point log splitter off my Jinma 284. It has a 4" cylinder with 24" stroke and it will split anything I throw at it with the tractor purring along at 1200 rpm's. I think it's only 7 gallons per minute but it's cycle time is plenty fast.
Chris
Thanks for your reply Chris. I've just had a response from the Jinma factory informing me that the 354's pump only delivers 8.7 gal/min so I'll have to think again.
   / Hydraulic pump specs Jinma 354 #4
Your problem is solved if you'd consider a PTO pump. Just buy one to meet/exceed your 11 gpm spec. I found one right here in the time it took me to type "pto pump 11 gpm". With a little more searching, I'm quite sure you'll find more reasonable/local pricing as well.
//greg//
   / Hydraulic pump specs Jinma 354 #5
Provided that your splitter has a reservoir for the hydraulic fluid, I'd recommend a PTO hydraulic pump. If the splitter doesn't have a reservoir of its own, you'd either need to add one to use a PTO pump or use the tractor's pump. I do believe that the tractor's pump would be reasonably adequate for most splitters.
   / Hydraulic pump specs Jinma 354 #6
I'd try the tractor pump first and if it didn't perform THEN, I'd fork over the money to get a PTO pump. bjr
   / Hydraulic pump specs Jinma 354 #7
I bet mine moves less gph but it does just fine.
Chris
//greg//
Thanks Greg, considering that but it does increase the overall cost by 30%.
   / Hydraulic pump specs Jinma 354 #9
i am not absolutely sure of this -But- if that pump is like most chinese engine driven models of the CBN-312-320 series , you may be able to replace the 7.- gallon unit with the 320 model which I believe is just over 10 gpm.
eventually i am thinking of this mod for my tractor Affordable had them, here https://affordabletractorsalesco.co...ategory=Hydraulic Pumps&category=Parts Center
this pump will also increase the speed of your FEL at the same time...
The other benefit is this is a virtual bolt on... and it only costs about $ 211 and leaves you a spare
Good Luck with whatever method you choose
   / Hydraulic pump specs Jinma 354 #10
If you do upgrade your hydraulic pump, make sure that you install another pressure relief vale in your system - preferably at the pump discharge. The pressure relief valves on the tractor should not be relied on. Also install a pressure gauge in your hydraulic system to monitor the pressure. Not having the proper relief capabilities will soon render your new upgraded hydraulic pump useless with a split casing. Don't ask how I know.
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
FRONTIER CA2072 LOT IDENTIFIER 41 (A53084)
FRONTIER CA2072...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
