I have an old 1949 Farmall M tractor with a Du-Al loader, the oil reservoir for the loader is in the loader's frame.
Can I add another hydraulic pump on my tractor's PTO shaft and use the same loader reservoir for the additional pump? The pump for the loader runs off the tractors timing gear and is very low volume.
If so, can I just "T" into the existing "supply and return" hoses (to the frame reservoir) with another open center set of valves for the additional pump on the PTO?
Thanks for any info,
RoninKS
RoninKS
