Hydraulic Pump, no load power use
   / Hydraulic Pump, no load power use #1
cmaas
Kubota L2800, Ford 555A
I am fitting a 3 cu. in. pump to a custom vehicle. The pump is used intermittently and is powered by the vehicle's motor. Rather than disengage it using an electric clutch I am wondering if I can just leave it engaged full time. Can anyone tell me approximately how much torque it takes to spin a 3cu. in. 30gpm pump when it's not under load?
   / Hydraulic Pump, no load power use #2
Many years ago I was working for a gear pump manufacturer and they dd not publish any data but a pump producing 28 GPM at 1750 RPM required approximately 3 HP just to circulate that flow at 30 PSI. I do not know how much the HP requirement would vary with a smaller displacement at a higher RPM.
Thanks. I think I will try without the clutch but make provision for it to be installed later.
   / Hydraulic Pump, no load power use #4
Good idea - especially if the pump is being run fast a lot of the time w/o using its considerable output. > If it spins slowly due to low engine speed most of the time you use the vehicle it wouldnt be so attractive to clutch it to save the lower parasitic power use.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
8ft x 6 1/2ft Shipping Container with Side Door (A51573)
8ft x 6 1/2ft...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
