Hydraulic pump flow
/ Hydraulic pump flow #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Does anyone know the hydraulic pump flow (gmp) of main pump. Not the power steering or comdined. My owner manual shows only shows the the total flow. Also IF possible what speed that would be at, pto or full throttle.
Tractor is a New Holland 2120 with a gear, not power shuttle /forums/images/graemlins/frown.gif.
Thanks
/ Hydraulic pump flow #2
2120 HYDRAULIC Specs.
Hydraulic pump capacity, gpm (lpm) 9.3(35)
Power steering pump capacity, gpm (lpm) 2.8(10.6)
Total flow of pumps, gpm (l/m) 12.1(45.8)
I believe it is rated at PTO speed. BTW Your 2120 is just a baby, I've had mine since 1987. The 2120 was one of the most popular models Ford ever made.
Andy
Thank you.
I needed to know the flow rate because I need to get some flow restrictors for my hydraulic multiplier i'm ordering.
The only thing I regret is not getting the hydraulic shuttle shift. But other than that it has done a lot of work. I'm at 700 hrs now.
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2014 JLG 6036 6,000lb 4x4 Rough Terrain Telehandler (A59228)
2014 JLG 6036...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
2005 Sterling Acterra Tender Truck (A61307)
2005 Sterling...
