Hydraulic pump flow
   / Hydraulic pump flow #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Does anyone know the hydraulic pump flow (gmp) of main pump. Not the power steering or comdined. My owner manual shows only shows the the total flow. Also IF possible what speed that would be at, pto or full throttle.
Tractor is a New Holland 2120 with a gear, not power shuttle /forums/images/graemlins/frown.gif.
   / Hydraulic pump flow #2
2120 HYDRAULIC Specs.
Hydraulic pump capacity, gpm (lpm) 9.3(35)
Power steering pump capacity, gpm (lpm) 2.8(10.6)
Total flow of pumps, gpm (l/m) 12.1(45.8)
I believe it is rated at PTO speed. BTW Your 2120 is just a baby, I've had mine since 1987. The 2120 was one of the most popular models Ford ever made.
Andy
Thank you.
I needed to know the flow rate because I need to get some flow restrictors for my hydraulic multiplier i'm ordering.
The only thing I regret is not getting the hydraulic shuttle shift. But other than that it has done a lot of work. I'm at 700 hrs now.
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
