Hydraulic pump adapter
/ Hydraulic pump adapter #1
284 International
International Harvester 284
I posted this same question in the parts section, but realized I may have better luck here.
I need to couple an SAE A (11 spline 3/4" male connector) pump to my tractor, which has an SAE B (13 spline 7/8" female connector) end.
What is the best way to do this? I can't find any direct adapter for this configuration.
Thank you for that site, J_J. I can't seem to find specifications or part numbers for splined connectors for these couplings. Are they special order items?
/ Hydraulic pump adapter #4
Did you look through the PDF on the tight side of the page?
L Type Hub - Spline Bore UPC Number Selection Table
Give them a call and ask if the spline chart is what you need.
Sorry, I should have been specific in what I couldn't find. It appears that there are only female couplings, no male ended connections, but I'll find out more tomorrow. Thank you, again.
/ Hydraulic pump adapter #6
I think I know what you are looking for, it's more like a sleeve. I have seen them and have been trying to think where I have seen them used on. Hang in there for a little while.
Leejohn, a sleeve-type adapter would work, or a Lovejoy coupling with a male splined end. Thanks.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
