Hydraulic PSI
/ Hydraulic PSI #1
bigbadbrad
2005 Kubota B2910
I have an 05 b2910, I find the that the loader is not as strong as it should be. Has anyone ever turned up the psi on the hydraulic system? Thanks!
/ Hydraulic PSI #2
Yes. I had a 2910 of about the same vintage and the system pressure was a good bit below specs. The system pressure is set with shims behind a plug on the transmission case. The loader also has a relief valve which is on the loader valve. I'm pretty sure the loader valve lets go first, then the trans case. You set the loader relief while operating the loader. Once that is set, you sheck the trans one by operating the 3PH at it's max capacity. On mine, the trans valve was releasing well before the specified pressure.
/ Hydraulic PSI
Thanks I also have another quick question on the loader valve in th float function it should "lock" in to float right? Cause mine does not. I have to hold it in the float position. kinda a pain to be holding it in float all the time, and I know it will be worse with the front blower on this winter. Is there a detent in the valve that could be the problem?
/ Hydraulic PSI #4
Yes it should lock into position. I have a B2710/LA402 and had the same problem with my loader when it was fairly new. It was still under warranty so they came to the house and fixed it for me. I wasn't here when they came, but I know they had to come back the next day because they needed a part, so they replaced something. I don't remember any more of the details of what they did.
/ Hydraulic PSI
well i guess i will start by taking the cover off of the top and see if i see anything wrong in there
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2027 . 500k BTU Wellhead Heater (A67714)
2027 . 500k BTU...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
