hydraulic problems with my farmtrac
/ hydraulic problems with my farmtrac #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
no hyd pressure as far as i can tell , no power steering loader won't work, 3 point hitch won't raise. i tried bleeding the air out , lots of white stuff, water and oil mix. any ideas what to do would be greatly appreciated. 535 tractor with a tarboro built loader. thanks, johnny
/ hydraulic problems with my farmtrac #2
/ hydraulic problems with my farmtrac #3
If you looked at the link above you will understand better what I am describing here. Turned out to be a 4-hour job -- I'm pretty slow with a wrench. I removed the left footboard and hydraulic pipe section under the footboard. Then I pulled the round cover on the left side of the trans housing. The wire-mesh intake filter attached to the inside of the round cover was covered with a slimy coat of material that looked like vaseline. When I cleaned up and reassembled, the hydraulics were like new again.
I caught about a gallon of hydraulic fluid that drained out the round port and a pint that came out the pipe leading to the spin-on hydraulic filter, so be ready with pans. I probably should have replaced all the hydraulic fluid, but I topped it off with about a gallon of fresh, and I'll see how it goes.
Good luck with yours, Johnny.
thanks for the help, got it working today, johnny
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
WAREHOUSE STEPS (A60432)
WAREHOUSE STEPS...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2008 New Holland T2420 (A60462)
2008 New Holland...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
