Hydraulic problem
   / Hydraulic problem #1
birch719
International 574
I have two International 574s. The rear hydraulic work, but can't lift the bucket. Any suggestions?.
   / Hydraulic problem #3
:welcome::tractor: This may help. Go the the SEARCH section at the top of this page. Type in International 574.This may direct you to a forum, post or thread that has some info for you. Good Luck.
   / Hydraulic problem #5
birch719,
You need to describe more of what you have and the components not working.
Does anything on the FEL /loader work?
Do you know the hyd flow path, from pump to the 3pt.
Do you have a hyd gage?
2006 International 7400 Dump Truck (A47477)
2006 International...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
1261 (A50490)
1261 (A50490)
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
