hydraulic problem with my 3 point hitch farmpro 2420
   / hydraulic problem with my 3 point hitch farmpro 2420 #11
If you replaced the pump and it is a good pump, and if the IN port is flooded, then when the engine is turning, the gear pump is turning, or should be pumping.
With all levers in neutral, there should be flow, but very little pressure. Now when you operate the loader, the loader should work and build pressure depending on load.
A hyd gage will tell you if you have pressure.
   / hydraulic problem with my 3 point hitch farmpro 2420 #12
Hello, I'm new to tractors but have a FarmPro 2420 2WD and the lift arms located at the back of the tractor just stopped working one day while I was connected to an Augger* digging holes for post to go in. I took apart the covers under and in front of the seat just to make sure everything was alright and it is. I then connected a hydraulic gage to the pump quick connect line and no pressure was showing so I replaced the pump and still nothing. I also checked the o-rings and they look fine and dandy. What else could it be? Please help, I have much work to be done. :/
hey did you ever discover the problem? Mine stuck in the up position this am.
let me know
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
