hydraulic problem with my 3 point hitch farmpro 2420
   / hydraulic problem with my 3 point hitch farmpro 2420 #1
four m
farm pro 2420
I have a jinma 03 farmpro 2420 ty290 2wd and my 3 point hitch will not raise up .I tried turning the knob under the seat ,and had no results. Does anyone have any idea where to try next ? thanks
   / hydraulic problem with my 3 point hitch farmpro 2420 #2
Is any other hyd function working.
Have you checked levels?
Is the pump running.
Do you have a hyd gage?
Do you have any QD's in the flow path?
I don't have a front end loader, where would I put the fluid?
   / hydraulic problem with my 3 point hitch farmpro 2420 #4
Should be a fill cap around the seat area.
Do you have a site glass to check level?
   / hydraulic problem with my 3 point hitch farmpro 2420 #5
four m
Do you have an operators manual?
Where would this sight glass be located?
There is a dip stick behind the seat it looks like the rear end area . I dont know if its for dydraulic fluid or something else?? thanks tom
Tx Jim
I have the parts break down books one for the engine and one for the tractor . Its written in chinese
   / hydraulic problem with my 3 point hitch farmpro 2420 #8
Hello, I'm new to tractors but have a FarmPro 2420 2WD and the lift arms located at the back of the tractor just stopped working one day while I was connected to an Augger* digging holes for post to go in. I took apart the covers under and in front of the seat just to make sure everything was alright and it is. I then connected a hydraulic gage to the pump quick connect line and no pressure was showing so I replaced the pump and still nothing. I also checked the o-rings and they look fine and dandy. What else could it be? Please help, I have much work to be done. :/
   / hydraulic problem with my 3 point hitch farmpro 2420 #9
Jkeen21:
Not sure on this one, where did you connect the Hyd Gauge? There should be 0 or low pressure when running and not moving ANY of the valves after the Hyd Gauge. The system is Open Loop that fluid flows out of the hyd res thru filter screen, into hard line and into pump, out of the pump thru valves steering divertor etc flowing freely until one of the spools is moved to divert fluid flow. Te fluid normally just goes straight back to the tank without pressure being developed. Pressure is resistance to flow the more resistance to the flow the more pressure will build. The normal flow simply goes straight thru one valve to the next all way till it goes thru the 3pt lift valve on right side of seat and into the tank to be recirculated. If you have a FEL on and have the valve between the FEL and the Pump by lifting the FEL with a load of rocks in it you will see like 1800+ PSI and if the load is more than the FEL can lift it will max out about 2200PSI where the relieve valve opens and bypasses the FEL cylinders lifting the load.
When you were digging w auger did you pull it UP too far? That will lots of time push the Lift Piston too far up and it cuts the seal in the lift cylinder. To inspect it the seat and the hydraulic tank and all have to come off, there are some procedures for this on line at Johns Tractor site or some of the dealers I think have links too.
Here are some good points for Jinma Maintenance & repair. JinmaInfo4
let us know what and where you were checking and if you may have over extended the hyd 3point to the raise up spot.
FYI: FOR ANYTHING JINMA OR CHINA TRACTORS GO TO THE CHINESE TRACTOR PAGE 3/4 DOWN TBN. Chinese Tractors
Mark
   / hydraulic problem with my 3 point hitch farmpro 2420 #10
Okay, I will inspect it all out and report back. Thank you, the help is very much appreciated.
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
