Should have put this info in my post. When I connect the QD's by color, white to white, red to red etc. when I pull back on the joystick or push forward the bucket will dump and roll. When I move the joystick left or right the boom goes up and down. After switching the QD's around everything works correct except for the down problem.
Just to be clear the following description is how the joystick lever should work:
If you pull straight back on the joystick lever the lift arms should go up.
If you push forward on the lever the lift arms should go down under hydraulic pressure. And if you push past past the detent the lift arms should fall rapidly.
This is the float position of the lift arms. In this position the lift arms will follow the ground terrain if you place the tractor in revers and skid the bucket on the ground. They will go up and down and the only down force in this float position is just the weight of the lift arms and bucket itself, the arms are free to float up.
If you pull the joystick lever to the left the bucket will curl up so that materiel in the bucket will be retained.
If you push the joystick lever to the right the bucket will dump so that material in the bucket will fall out.
If you push the joystick lever FURTHER to the right you will feel extra spring tension and the bucket will go into regeneration mode. This is a fast dump of the bucket. I won't go into details on how this works, but it will be noticeably faster dump then just the normal dump position.
If you valve and hose hookup does not work this way, then you have something hooked up incorrectly or you valve is broken etc.
If you
