Hydraulics were erratic on the loader. Operating the control valve to raise and lower the bucked caused the bucket to lift slowly or not at all. Hydraulic fluid is at proper level. I loosend one of the hoses at the valve, started the engine and worked the valve thinking there was debris in the valve. Pumped some oil out and shut down the engine. The next day I cranked it back up and the hydraulics did not work at all. No movement at all and now no pressure from a loosened line at the valve. The pump was also making a new noise for the past couple days. I was thinking the pump was bad and tried to get the pump off but could not get to the top-inside bolt to loosen it. Does anyone have any suggestions?
