Hydraulic problem on 755 compact tractor
/ Hydraulic problem on 755 compact tractor #1
txdave123
texas
ford 2000
Hey Guys, I just bought a 755 diesel 2 wd w hydrostatic everything. The unit had been sitting for several years. I put a battery in it and it cranked right up! When I cranked on it at first the hydraulic lever was up and the rear 3 pt was going up. I lowered it and after it started and smoothed out the hydraulics were working and the steering was working but slow. Now it does nothing . Is there a clutch for the hydraulic pump or safety switch? Perhap the filter or screen is clogged? I haven't changed the filter yet and is the screen behind the filter or in another location? Also I read somewhere that the pto wont engage unless the engine rpms are over a certain speed. Is this true? Thanks in advance Dave
/ Hydraulic problem on 755 compact tractor #2
The screen is directly below the rear PTO shaft. It's behind the fitting where the main supply pipe exits the rear cover.
The PTO has an interlock which require the operator to be in the seat before it will engage.
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
