hydraulic pressure release tool
   / hydraulic pressure release tool #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I always go through the release of pressure before I detach my grapple, but it is good odds that the grapple will build pressure just sitting there. SO, finally took the time to build my version of a release tool, hopes it works.
Untested.
   / hydraulic pressure release tool #2
The old farmer way to do this is bang the male tip onto a piece of hard wood or metal, which will push in the ball and release the pressure. (plus get some oil on your pants. :rolleyes: )
The best solution is the female coupling where you insert the the male coupling then rotate a lever that pulls the two together even under pressure. I know Steiger tractors had this type, not sure who made them.
ISZ
I've banged tips to the point of denting the ball. I've had to crack the fitting 3 times now, hopefully no more.
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
