hydraulic pressure loss
   / hydraulic pressure loss #1
rockinmywaypa
Platinum Member
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
Maybe somebody can help me out. I have a JD 3130 that loses its hydraulic pressur whenever I lower the 3 pt lift arms, as long as they are carried in the full highest spot everything is fine. I have a loader on that I mounted but this problem only started a few months ago. Ant ideas like could there be packings in the lift cylinder(rock shaft) that could be damaged. Thanks.
   / hydraulic pressure loss #2
Re: hydraulic pressure loss
A little confusing. The pressure should drop when lowering hitch. Do you mean any position except max lift? Many tractors also go to low preesure mode at max height. Normally when a lift piston **** is bad, hitch will hiccup and not maintain any position(off or running). Possibly an unloading valve or position control spool problem. I think you need to invest in a repair manual, as most have general hyd troubleshoot section.
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
10' CONTAINER (A51248)
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
International Cab and Chassis (A51692)
International Cab...
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
