hydraulic pressure loss
   / hydraulic pressure loss #1
rockinmywaypa
Platinum Member
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
Maybe somebody can help me out. I have a JD 3130 that loses its hydraulic pressur whenever I lower the 3 pt lift arms, as long as they are carried in the full highest spot everything is fine. I have a loader on that I mounted but this problem only started a few months ago. Ant ideas like could there be packings in the lift cylinder(rock shaft) that could be damaged. Thanks.
   / hydraulic pressure loss #2
Re: hydraulic pressure loss
A little confusing. The pressure should drop when lowering hitch. Do you mean any position except max lift? Many tractors also go to low preesure mode at max height. Normally when a lift piston **** is bad, hitch will hiccup and not maintain any position(off or running). Possibly an unloading valve or position control spool problem. I think you need to invest in a repair manual, as most have general hyd troubleshoot section.
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
KUBOTA U48-5 EXCAVATOR (A51246)
KUBOTA U48-5...
UNUSED 3 PRONG BALE SPEAR (A51248)
UNUSED 3 PRONG...
20704 (A51694)
20704 (A51694)
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
