3-Point Hitch Hydraulic pressure loss
   / Hydraulic pressure loss #1
David V
DeRidder Louisiana
LS K 5055 / LS XU 6168C
I have a 2013 LS 5055 low hours, runs great but i loose my setting on my back lift when I let off the throttle. I pull or trailer with hay and when traveling down tne road witn a steady throttle it holds steady where I set it. I let off the throttle and slow down and the lift drops....any clues? Front loader does not does this.
Thanks Dave
   / Hydraulic pressure loss #2
Partially stuck open valve that can keep up at higher flow but not when rpms, and subsequently flow, drop?
Just a wild stab in the dark. I don't know as much as I should about tractor hydraulic system operation; I need to schedule time to study.
Case 580M Series 2 Loader Backhoe (A53117)
Case 580M Series 2...
2006 Ford E-350 Passenger Van (A51692)
2006 Ford E-350...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
200722 (A51247)
200722 (A51247)
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
