3-Point Hitch Hydraulic pressure loss
   / Hydraulic pressure loss #1
David V
DeRidder Louisiana
LS K 5055 / LS XU 6168C
I have a 2013 LS 5055 low hours, runs great but i loose my setting on my back lift when I let off the throttle. I pull or trailer with hay and when traveling down tne road witn a steady throttle it holds steady where I set it. I let off the throttle and slow down and the lift drops....any clues? Front loader does not does this.
Thanks Dave
   / Hydraulic pressure loss #2
Partially stuck open valve that can keep up at higher flow but not when rpms, and subsequently flow, drop?
Just a wild stab in the dark. I don't know as much as I should about tractor hydraulic system operation; I need to schedule time to study.
JOHN DEERE 48" REAR BAGGER (A51248)
JOHN DEERE 48"...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
Zero Turn Mower (A51691)
Zero Turn Mower...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
PALLET OF MISC SIZE EXPANDED METAL (A51247)
PALLET OF MISC...
