Hydraulic power tc40d
   / Hydraulic power tc40d #1
Bowvalleyboy
New Holland TC40D
Hello, I'm having power problems problems with my loader and 3 point. They have very little power at low idle and not as much as they should have when I throttle up. I replaced fluid, filters, and o rings on the suction line. The suction line screen had some shavings but I didn't think it was excessive. No chattering, just poor power. Hydrostat seems to be work but does wine it the cold weather. I also replaced the o rings between the pump and the diverter valve. About 1500 hours on the tractor.
   / Hydraulic power tc40d #2
Best thing to do would be to check the pressure. Put a tee in one of the loader lines & run it to the end of the cylinder stroke & check pressure. Should be around 2000 psi at full throttle.
I replaced the hydraulic pump. It works the way it's supposed to.
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2015 DRAGON 130...
2018 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2018 CUMMINS...
2025 epic golf cart (A55758)
2025 epic golf...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
