Hydraulic power tc40d
   / Hydraulic power tc40d #1
Bowvalleyboy
New Holland TC40D
Hello, I'm having power problems problems with my loader and 3 point. They have very little power at low idle and not as much as they should have when I throttle up. I replaced fluid, filters, and o rings on the suction line. The suction line screen had some shavings but I didn't think it was excessive. No chattering, just poor power. Hydrostat seems to be work but does wine it the cold weather. I also replaced the o rings between the pump and the diverter valve. About 1500 hours on the tractor.
   / Hydraulic power tc40d #2
Best thing to do would be to check the pressure. Put a tee in one of the loader lines & run it to the end of the cylinder stroke & check pressure. Should be around 2000 psi at full throttle.
I replaced the hydraulic pump. It works the way it's supposed to.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2025 JMR 40in Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
