Hydraulic power angle
/ Hydraulic power angle #1
zmansmac
Arcadia Township, Michigan
Kubota B7500
Last year I modified my 6 foot rear blade so I can mount it in place of the loader bucket on my B7500. It worked great, but it's a hassle getting off and on the tractor to change blade angle. So I'm thinking about setting up a power angle. I don't know much about hydraulics, but I'm starting to learn. A friend at work with some experience in this area told me that I need to plumb in an open spool valve in series with the inlet line going to my loader valve. And then use 2 single acting cylinders like they do on pickup truck rigs. Just wondering if anybody out there has already done this and how.
/ Hydraulic power angle #2
You can use a single double acting piston (2 hoses on cylinder) and use the loader valve to control it. Less work to do welding on one cylinder vs. 2 and no change to the hydraulics.
The only advantage to using single acting plow cylinders is if you hit an immovable object, the blade will change its angle. A double acting cylinder will have no give like the single acting.
Junkman,
Thanks for the quick reply. It made me realize that I neglected to say that I don't want to sacrifice either the up/down or the dump/curl functions as both have been very useful last winter. So I would need another valve to control the power angle function.
/ Hydraulic power angle #4
zmansmac, you wouldn't happen to have a photo of your blade would you?
srs,
This is the only decent picture I have from last winter. I meant to post more detailed pictures of my setup but decided I should wait until I used it a bit and made sure there were no problems. It's proven itself out last season but now I'll probably wait until I get the power angle set up to post a bunch of pics.
Peterson Horizontal Grinder (A62613)
Peterson...
1042 (A60430)
1042 (A60430)
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
4021 (A59228)
4021 (A59228)
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
