hydraulic pin removal
   / hydraulic pin removal #1
Village Idiot
Northern NH
Kubota 4240; Deere 4020
Hi all,
I'm trying to take the hydraulic piston off of an excavator dipper stick. I can drive the pin out easily (the pin that fits through the end of the hydraulic piston "T"). I thought the piston would then drop free, but it seems to be stuck in there. I think that the bushings that fit in the end of the piston have gotten jammed against the inside of the dipper stick collar. I tried drifting the bushings back toward the center, but I can't get a good enough purchase on them to apply much force. I tried retracting and jerking on the dipper cylinder itself, but the thing won't break free. Is this a common problem with a solution I just can't figure out? Am I supposed to use some type of bearing puller to separate the bushing from the outer collar? My only other thought was to put a piece of wood against the end of the piston and hit it with a maul trying to force the "T" onto the bushing.
This is for an old Drott Cruz Air 40 so the piston size is pretty big (5"+ dia) and even the pin seems like 2.5"+ dia and at least a foot long.
Thanks for any help
   / hydraulic pin removal #2
That is what happened the bushing has moved in the cylinder about the only way to get it apart is to cut the bushing out with a torch you will never move the bushing any other way.
Crap. I was hoping there would be an easy fix. I just got the machine at an auction, and it is about 12'6" tall. I can't find anyway to get it home without taking the dipper stick off so I can lower the boom a little more.
Thanks guys.
   / hydraulic pin removal #5
Might try hooking up the other end and put some power to it, might bend enough to get it to pull the cyl out.
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
