hydraulic pin removal
   / hydraulic pin removal #1
Village Idiot
Northern NH
Kubota 4240; Deere 4020
Hi all,
I'm trying to take the hydraulic piston off of an excavator dipper stick. I can drive the pin out easily (the pin that fits through the end of the hydraulic piston "T"). I thought the piston would then drop free, but it seems to be stuck in there. I think that the bushings that fit in the end of the piston have gotten jammed against the inside of the dipper stick collar. I tried drifting the bushings back toward the center, but I can't get a good enough purchase on them to apply much force. I tried retracting and jerking on the dipper cylinder itself, but the thing won't break free. Is this a common problem with a solution I just can't figure out? Am I supposed to use some type of bearing puller to separate the bushing from the outer collar? My only other thought was to put a piece of wood against the end of the piston and hit it with a maul trying to force the "T" onto the bushing.
This is for an old Drott Cruz Air 40 so the piston size is pretty big (5"+ dia) and even the pin seems like 2.5"+ dia and at least a foot long.
Thanks for any help
   / hydraulic pin removal #2
That is what happened the bushing has moved in the cylinder about the only way to get it apart is to cut the bushing out with a torch you will never move the bushing any other way.
Crap. I was hoping there would be an easy fix. I just got the machine at an auction, and it is about 12'6" tall. I can't find anyway to get it home without taking the dipper stick off so I can lower the boom a little more.
Thanks guys.
   / hydraulic pin removal #5
Might try hooking up the other end and put some power to it, might bend enough to get it to pull the cyl out.
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
