Hydraulic or PTO driven wood loader ideas
   / Hydraulic or PTO driven wood loader ideas #1
HogSlayer6
MO/KS/AR
Case 930, Ford 1900 and 8N
I am trying to build, envision, create a concept of a powered conveyor belt type system that I can use to load firewood into the back of my dump truck. Not that I don't enjoy a good workout, its just easier to get the kids to play along when power tools suppliment the manual labor. I have seen roofing companies using something like this to lift shingles up to roof tops. Does anyone have any plans from one they have built, good ideas where I would buy components to build one, or maybe where I might find one in a salvage yard.
   / Hydraulic or PTO driven wood loader ideas #2
A hay bale elevator is all I can envision. Might be longer than you need, but they should show up on farm auctions.
ron
   / Hydraulic or PTO driven wood loader ideas #3
Bale elevators do indeed work very well.
First modification: 1/8" plate in place of the tin trough. (at least on the sliding surface...)
Second modification: Beefy crosslinks every 2-4 feet on the chains. Picture lengths of 1-1/2" or even 2" angle.
Third modification: Put an apron at least 3 feet long hanging off the top end & braced to slope down at around 45 degrees.
Fourth modification: Build a feed hopper at the bottom to throw the wood into.
Make sure the conveyor is top driven & mount a beefy hydraulic motor to direct-drive the sprockets.
Make sure the supports are really solid. (or do like I do & mount the whole thing rigidly on an old truck chasis with the splitter on one side directly feeding the conveyor.
I sure wish I still had pictures of the last one I built. Spent about $500 building it (not counting the old truck) & used it to earn about $200K over the years.
   / Hydraulic or PTO driven wood loader ideas #4
Some old elevator information; sorry I don't know how to make PDF's smaller
  • 165.pdf
  • 166167.pdf
  • 168169.pdf
  • 170171.pdf
  • 172173.pdf
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
28013 (A50322)
28013 (A50322)
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
