Hydraulic Or Mechanical Drive - Your Thoughts?
   / Hydraulic Or Mechanical Drive - Your Thoughts? #11
I vote for Mechanical. As you stated "Simple & Effective". What is wrong with that?
So with that in mind and you leading the way, onlookers such as myself might want to build one too. We all don't have good hydraulics sources available ya know.
The more I think about it and talk about it to others...I think this one will be mechanical drive...Once I'm done I'll post pics...like I said, I'm still in materials gathering mode. I expect I'll be using it this summer sometime...
   / Hydraulic Or Mechanical Drive - Your Thoughts? #14
I've used both on implements I've made and each has its advantages
hydraulic has the simplicity of lay out , you can run hoses anywhere and put the motors where the work is and maintaining is simpler.
my stonepicker has 2 motors in series to perform separate functions and in series with the rockshaft with no problems.
the downside of hydraulic is cleaning the connectors when hooking them up.
i put the motors on removable mounts to use on different implements.
2013 Chevrolet Caprice Sedan (A56859)
2013 Chevrolet...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
