Hydraulic or HST Filter?
/ Hydraulic or HST Filter? #1
1990F-150
Sanger TX
2023 LS MT240HE. Kioti ZT. Honda Pioneer 520. Ford 8n. Ford 9n. Massey Ferguson 1080. Ford 2000
I'm doing the 50-hour service on my MT240he, and am a little confused about what hydraulic filter I need. The manual states a hydraulic filter, but the website has both a hydraulic filter and an HST filter. Anyone know which filter to get? and what hydraulic fluid should I get to replace the amount lost with the filter?
/ Hydraulic or HST Filter? #2
I would change both filters. Mine has a napa1551 hydro filter. The larger filter is a Donaldson from the factory but I don't recall the number, I can look when I get home. I use a udt equivalent oil.
/ Hydraulic or HST Filter? #3
if you have a HST, you want to replace both. The manual has pages for both HST and Mechanical, make sure you are looking at the HST one.
If you put a small shop vac on the hydraulic fill port, you won't lose much fluid when you pull the big filter, really just what's in the filter will come out. If you don't use the vacuum trick, you risk dumping 8 gallons.
I did mine a few years ago, and only needed a quart or two. Back then WallyWorld had "Premium Heavy Duty Tractor Hydraulic and Transmission Fluid" on the shelf. Looks just like this, but without the Premium/Heavy Duty tag, might just be marketing, and you only need a little bit. Robot or human?
Sounds good I’ll do both filters. I’ll definitely try the shop vac trick. spilling out all the hydraulic fluid would make for a bad day in the shop.
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Volvo Water Truck, 3306 Cat Engine (A62679)
Volvo Water Truck...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
