hydraulic on a farmall C
/ hydraulic on a farmall C #1
farm boy00
Veteran Member
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
I have a farmall C with the hydraulic block in middle. Haven't got it to work and added fluids. Any other ideas and how do you lubricate the control levers
/ hydraulic on a farmall C #2
Are the levers moving but nothing is happening, or is nothing moving?
If nothing is moving try disconnecting the lever from the rod that goes down to the touch control. Then see if you can move the rob front to back. You should see the lift arms move, but if they still don't move you may need to rebuild it.
Levers are frozen but i unhooked the rods ave they move freely. I am trading the tractor off Thursday for a Swenson 8ft quick attach snow plow with under the hood pump
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2017 Maserati Ghibli Sedan (A61574)
2017 Maserati...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
