Hydraulic Oil
/ Hydraulic Oil #1
GWP
Bloomfield, NM
LS S3010
What kind of Hydraulic Oil should I use in my LS 3010 Tractor.
/ Hydraulic Oil #2
What does your Manual say????
/ Hydraulic Oil #3
I don't know what an LS 3010 is, nor what year, but most tractors have wet brakes, combination hydraulic, transmission, and differential oil sump, hydrostatic steering and all which requires the premium fluid, not the stuff you put in your 1960's relic. I usually look for the JD 20C rating on the back of the container as if any are going to be listed that one usually is due to the JD popularity. TSC Premium Universal Hyd. Fluid. is rated for a wide variety of equipment (look on the back of the container) and is what I use.
Mark
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
master diesel generator (A64553)
master diesel...
PORTA POTTY (A67714)
2013 FORD F-150 (A67714)
2013 FORD F-150...
FARMTRAC 555 TRACTOR (A65057)
FARMTRAC 555...
2013 BOMAG BW211D SMOOTH DRUM ROLLER (A67714)
2013 BOMAG BW211D...
