Hydraulic oil specs
/ Hydraulic oil specs #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Went to Tractor Supply today for a little shopping. My 3038H book specifies "API GL4 ISO VG 46/68" for Hydro oil. However when I picked up a bucket of the Traveller "ISO 46" fluid it said upon other things "NOT recommended for wet brakes"??? Did'nt get any yet, but am confused by the book reference to ISO 46, but not recommended for wet brakes. What gives?
/ Hydraulic oil specs #2
You want universal-tractor-trans-hydraulic-fluid not "OIL". Both of these should meet your specs.
Traveller® Universal Tractor Trans/Hydraulic Fluid, 5 gal. - Tractor Supply Co.
Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid: Automotive : Walmart.com
OK, forget my loose reference to "OIL". My point was the owners manual calls for ISO 46, but the label on the bucket of fluid (ISO 46) states not recommended for wet brakes. My question was do you really use an ISO 46 type fluid? And the manual does have a few errors/omissions so this might be another one.
/ Hydraulic oil specs #4
Tarnold, send me your email address, and I'll send you a spec sheet with various brands of hydraulic oil that are approved by LS.
/ Hydraulic oil specs #5
Could you post that on the LS sticky thread for oil & filter info please?
/ Hydraulic oil specs #6
iso type hyd oils are for dedicated hyds systems.. not common sumps. also fine for bottle jacks and some self contained power steering systems
/ Hydraulic oil specs #7
I missed this request....well hopefully "better late than never" still applies after a year and a half. Here's that list, and I posted it in the sticky thread too.
  • LS Hydraulic Fluid Specs and Compatibility.pdf
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2022 EZ-GO ELITE...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
