Hydraulic oil question
/ Hydraulic oil question #2
Members have posted using that oil and it worked fine. TSC has two Travellers hydro oil. Get the one you posted. It will say "Premium". It's a multi weight as Kioti uses.
/ Hydraulic oil question #3
For Hydraulic Fluid at TSC, we always recommend the Shell Rotella HD Trans/Hydraulic Fluid. We have had a couple of performance issues with the Traveller products, especially in HST Transmissions.
What type of issues?
/ Hydraulic oil question #5
Whining .....and poor pedal response....especially in colder temperatures.
Thanks, our local TSC has the Shell Rotella in stock so will pick up a 5 gallon bucket.
Any hints to transferring from the bucket to the tractor?
/ Hydraulic oil question #7
If your adding , just to top off the tractor, get what the dealer put in it. Have them bring a pale when they come Saturday.
/ Hydraulic oil question #8
You can buy a hand pump that fits the top of a 5 gallon pail, and has a hose to pump the oil where you want it...
SR
/ Hydraulic oil question #9
Unless changed recently the Shell Rotella HD is actually Spirax S4 TXM which supercedes the Donax TD that Kioti called for in their owners manuals or at least in my owners manual for my DK45S.
Does that make the Shell a better or worse choice?
/ Hydraulic oil question #11
that would make it an OEM recommended oil. So if your owners manual calls for a Spirax S4 TXM or Donax TD than the Shell Rotella HD tractor and hydraulic fluid meets all the OEM specs. Spirax and Donax are Shell products.
/ Hydraulic oil question #13
Many thanks for this. I used the Spirax last time but it was hard to find and TCS stores are common here.
/ Hydraulic oil question #14
Just ordered this. Don't know how good it will be yet.
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
2001 Ford F-550 Truck, VIN # 1FDAW56F81EC40182 (A65563)
2001 Ford F-550...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
